4 wheel alignment. where can i get it done
chaps believe it or not no one in my area will adjust the subframe on my vrs now ive had the arb changed. Rang a few places and they all have the lazer alignment kit but wont touch my sub frame settings. Even rang the local dealer and they say it shoulnt need doing.....am i going mad?
update: found someone whos going to do it if i help them. They have lastest kit but not sure if you check it on ground and then again record values suspended and then it tells you what adjustment to make before you lower it to ground and this brings it back into the green. Is there a tutorial out there for adjusting this so i can get it done.
Not rocket science is it???
