Help: Blaupunkt ipod interface
Hello.
Help/advice needed please
I've got a Fabia VRS with the Blaupunkt woodstock DAB 54 fitted, with the extra 5 disc changer under it. I also have a nokia bluetooth handsfree kit all wiered in nicely.
Today i tried to also connect my ipod using the propper Blaupunkt interface cable so all the info would be on the screen. However, after pulling the dash apart i found that the handsfree kit takes up all the connectors and leaves no room for the ipod, even though the headunit does have two seperate aux outputs.
So, problem one. Can you split or get another adaptor to run both at the same time, or can i only have one?
Problem two, i disconnected the handfree part to check that the ipod cable worked but it didn't! The ipod did register the connection and kept showing "ok to disconnect", and at best you would get a quick 1 second blast of music, then it would stop. Anyone have any idea's why it would be Intermitent?
Problem Three: The 5 disc changer no longer fits properly, sits just a few mm short of where it was before.
Any suggestions?:confused:
