Changing the oil pump
What's involved when changing the oil pump? Is it straightforward enough? Anything to watch out for?
It's a pain to do but not rocket science. You have to drop the sump.
It is worth replacing the crankshaft oil seal. You will also need a suitable sealant for the oil seal housing. If in doubt use the Skoda Sealant.
Check the chain and sprocket for wear - Teeth should be symmetrical.
Chain tension - 4mm max deflection.
On what engine?
Sorry 1.8T
As said its pretty straight foward. All you need is sealer for the sump, the oil pump, strainer and gasket.
Drain the oil
Drop the sump
Unbolt oil pump
Push the chain tensioner across
Remove pump
Fit new pump and hook chain onto drive gear
Clean up sump and block of old sealer
Refit sump with new sealer
Refil with oil
Might as well change the filter while your at it
Run up and check.
Thanks!!
