power steering top up !
:thumbdwn: Had a look last night at topping up the power steering reservoir (Fabia 1.9 TDI ), after looking all around the engine bay I just could not see it anywhere ( not like the OCY which is on the top ! ) so I reverted to looking in the handbook and it shows it in between the battery and the front headlight, upon looking in this area I still could not see it :( so I had a look at my lads VRS Fabia and his could be seen below the battery in the wing, so going back to the wifes car I could just make out the edge of the cap buried below the battery case and some cables. How are you supposed to get access to it ? it looks as though I would have to remove the battery and move some cables just to be able to remove the cap nevermind adding fluid to the container :mad:
Yup, that's it. It can be reached with double jointed wrists, but sensible to take battery out as you can't judge levels from the side. Be positive - it's an opportunity to clean the terminals and the battery-top fuses, but do note where the battery panels go as you pull them apart or you'll have one over when you put it back together (how do I know that?)
