Strange Columbus map problem
I recently did the map update to V3 and all went well with the update process, but now I have another issue.
My MFD3 is a skoda unit with green display/lighting and skoda part number. Prior to the V3 update my unit showed Skoda service centres as a POI, now with V3 for some reason these have been replaced by VW ones. Looking at the map DVDrom, it does contain the skoda service centres but decided to copy VW ones over for some reason.
Hi Mannyo,
Mine did the same! Did you buy your unit new or off the 'tinternet? I have a theory that some are returned units (ones that developed a fault, but were fixable) & that they canabalise them to make a useable unit (I know some one who worked for an electronic comapany who was doing this!!!). In that case some of the electronics might remember they were in a WV branded unit before! When the disk is inserted, the FW should recoginse the brand of car the unit is in and install the correct data, AFAIK!
Mine now also starts up saying "Volkswagon Navigation"! I'd be interested if there is a fix too, just 'cos it's "one of those things"!
Mine still comes up with the skoda logo, but yes it was purchased online and is used. I may try and see if I can work round it by using the POI program in another thread to replace the VW service centres with Skoda ones.
Mine was purchased new and after the V3 disk suddenly wanted to become VW.
Not too sure why either as I know the update disc I used was sucessfully used elsewhere.
Sounds like the update procedure is perhaps using a script that they wrote first for VW-equipped cars and then didn't change it for the rest of the group! Especially if the Skoda files are on the disc :)
Is there a way you can just copy the Skoda POI files over manually?
Steve
Mine did it the other way around. Have a RNS510 (VW, with VW startlogo) and the V2 maps. It automatically showed and shows the skoda dealers? :thumbup:
I think I have found the file, and what to change to fool the skoda POI's onto the columbus
In folder, D:\tpd\ntcWeu_eu_20070806\ENG there is a file named eng.lsc, and it contains this.
CAR-BRD 20 40020
CAR-BR 20 VOLKSWAGEN
CAR-BRD 22 40022
CAR-BR 22 SEAT
CAR-BRD 23 40023
CAR-BR 23 SKODA
If I can pluck up courage, I may try changing it to:
CAR-BRD 20 40023
CAR-BR 20 SKODA
CAR-BRD 22 40022
CAR-BR 22 SEAT
CAR-BRD 23 40023
CAR-BR 23 SKODA
which should in theory load the 40023 (skoda stations) in place of VW ones
So it looks like they may have Skoda/VW the wrong way round. I wonder how many VW's are now driving round with skoda stations.
I wonder if fiddling with these lines a little maybe all thats needed, although the issue maybe elsewhere. I have attached the file zipped if anyone wants to have a play.
TPD-GRP 10014 11000 9112 9102 11001 11002 7366 11003 11023 7312 11004 9966 11017 7363 11007 11006 11008 7352 11011 11012 11015 7314 31000 11016 11035 9969 7317 31001 11022 11024 7311 7339 5130 11026 7315 40022 11027 7334 11028 7602 11030 7316 7379 11031 11034
TPD-GRP 10015 11000 9112 9102 11001 11002 7366 11003 11023 7312 11004 9966 11017 7363 11007 11006 11008 7352 11011 11012 11015 7314 31000 11016 11035 9969 7317 31001 11022 11024 7311 7339 5130 11026 7315 11027 7334 40023 11028 7602 11030 7316 7379 11031 11034
TPD-GRP 10016 11000 9112 9102 11001 11002 7366 11003 11023 7312 11004 9966 11017 7363 11007 11006 11008 7352 11011 11012 11015 7314 31000 11016 11035 9969 7317 31001 11022 11024 7311 7339 5130 11026 7315 11027 7334 11028 7602 11030 7316 7379 11031 40020 11034
These lines appear to contain what to load for seat/skoda and vw.
englsc.zip
Edited by mannyo
Wow! Keep me posted on how this goes, I've been watching this thread (& othes in VW Navi forum), but I think it excedes my level of computer literacy by a mile! I lost it at the creating ISO images bit!!!!!
Sorry Mannyo, mine still has the Skoda logo on the Columbus, but if you start up the car with the Columbus in the "Maps" mode it shows "Volkswagen Navigation" in the MaxiDot!
I think the problem is that the unit thinks it is VW and based on that loads the VW dealerships as POI's.
It might be worth someone trying a Skoda V3 disk to see if that makes a difference. I know it shouldn't but you never know.
Hedge, its interesting to see magic62's post where he has a VW unit and it loaded skoda POI's.
I bet if he starts it up with radio (or audio can't remember) selected on the Maxidot it will say Skoda as mine says VW Navigation the same as Uncle Bulgaria.
I have created a modified eng.lsc file and it seems to work correctly with the poi edit program mentioned in another thread.
I have done the neccessary, so may test it at some point running from the DVD and see if skoda stations now display. Anyone know where there is a skoda dealer and not a VW one.
Dennis Horton is Skoda only.
Kingsley Road
Lincolnfields
Lincoln
Lincolnshire
LN6 3RS
Claybank Manchester and Robert Eardley & Son in Crewe spring to mind for me...
Steve
