campaign 26e6 - A cynical person would say....
.....that the re-flash of the ECU under this non-safety 170TDI recall or whatever you want to call it, saps a noticeable amount of power and torque....VW's attempt to avoid DPF future issues perhaps....discuss (10 points)
You got anymore info on this ?
Clicky below for more general info in large thread.
I just don't believe i have anything like 170 bhp anymore feel more like a 140.
Seconded
It seems to be intermittent power too, sometimes it seems fine, some others it feels worse than SWMBOs 1.4 Corsa. :rofl:
Bahnstormers RR runs don't show much of a difference other than the torque ramp in the other thread, mind...
Mine is being re RR'd next month at a place where it has run before, so will have graphs with the same scales for comparison of curves...
http://briskoda.net/octavia-ii/vrs-pd-170-engine-management-software-disk-part/120394/
There is IMHO nowt wrong having had the 26E6 work done; check out my comments in the thread you haver linked.
A couple of points; if you look at the power graphs there is noticeably more torque to my car (different shape to the curve) between 1,000 and 1,500rpm. Additionally, tested by Superchips a couple of weeks ago now, post 26E6, I had a max of 187bhp. Tested at JKM earlier in the year I had 189bhp; effectively the same. No problem.
The words 'skin', 'pull' and 'rice pudding' come to mind actually. Maybe it needs to adapt.......................
My car has a flatter torque curve that I put down to having a K&N 57i intake; gives me less torque than OE in low/mid range but more over 3,000rpm (torque and power).
Just had my car updated at its first service (they also changed the sensor associated with the DPF even though they had already changed it once under warranty a few months ago).
Driving up the road from the garage, it felt like they had replaced the turbo with a smaller one! However, over a bit of driving the power seems to have returned.
It definitely feels a bit more progressive when it comes on boost, not quite as brutal. After that it seems to drive very similar. I will see how it feels over the next few weeks.
I assume this is only an issue on the PD and not the CR?
Yes it's a PD issue, and only on certain chassis numbers. Mine is about 18 months old.
