What does this code mean?
Hi, just connected vag to my 2006 Octavia II did a full auto scan and got the error below, anyone know what it means?:thumbup:
005784 - Please Check DTC Memory of Steering Wheel Electronics
P1698 - 001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 11101011
Bin. Bits: 11000000
(no units): 0.0
Found what the problem was last night, with the radio on I used the steering wheel control to change between my stored radio channel 5 and 6. And will only select these two, but if you manually press the radio button for 1,2,3,4 it is ok. Noticed that I loose the black arrow at the end of radio station name on button 5, but when you do this manually the arrow remains.
Anyone else had this problem, and will I need a new steering wheel. No overly worried as car is under warranty.
