ECU number
Is there any way i can find out my ECU number without ripping the car apart to find it? Its an Octavia VRS on an 02 plate.
Plug vag-com in.
Will that not just tell me a code on the ECU rather than the actual number of the ECU?
No, it will also give the part number of the ECU as in:
Address 01: Engine Labels: 036-906-014-AHW.lbl
Part No: 036 906 014 AA
Component: MARELLI 4AV 2444
Coding: 00000
Shop #: WSC 00000
thanks i have a code reader will that do the some thing? if not were can i go and get one or get it read?
Check the VAG COM map/locator.
Code reader may or may not depending on what one it is but id suspect no.
were will i find the VAG COM map/locator:confused: dont konw alot about cars :(
On your model of car i would expect it to use the following ECU
skoda_octavia_1.8T_Bosch_ME7.5-1_180_06A906032HN_0261207440_363908
thanks mate
