Skoda fabia 1.4tdi heater probs
Hi
The heater on my fabia will only work on position 4. Does anyone have any idea what the problem may be Thanks
Search or post your question here.
Welcome to the site :)
welcome
Hi - this should be moved to fabia 1 forum. But in answer to the Q, there is a resistor pack behind the dash with 1,2,3,4 on it which controls the speed. Your no.4 has probably died. The resistor packs are relatively inexpensive.
Thanks for that. I will have alook tomorrow.
Your correct in whats wrong but the reason why is a little off ;)
The blower motors is fed by 12v, depending on which speed you have it on depends on how many resistors are added to the circuit to alter the fan speed. Speed setting 4 is direct without going through the resistor which is why when the unit fails you still get speed four.
That's why you you're a master tech. :rofl: I actually read the O.P's question wrong, I thought that only speed 4 was dead and 1,2,3 were working. I shall bow down to your greater knowledge ;):thumbup:
welcome to briskoda
Davy
