Reverse lamp sensor
barrywi
I believe it is either on the bottom front or back of the gearbox... hence why labour can be pricey... means draining oil out of the box usually unless you can whip the old one out and stick the new one in quick enough! lol
Hy
It's located on gearbox. If you kneel down on your knees and look on lower part of the gearbox you will see wiring connector. That's the reverse lamp switch.
Be careful and have new switch prepared becouse gearbox oil will become to leak! You can use your thumb to plug a hole while you changing a reverse lamp switch.
