Engine light come on, car running well?
As title really, engine light come on but car running well with no apparent problems. Are there any faults that would cause this or do i just need a diagnostic? If so, any one with a VAG-COM lead in the Gloucester/bristol area?
Ta
Edited by nozzer
You will need to get it plugged into VAG-COM/code reader/dealer computer. There are a fair few things which can put the EML on without other symptoms but without the fault codes you have little hope IMHO.
I keep getting the same fault code (can't remember the code at the mo) which relates to the evap having low flow (black cannister on o/s inner wing with one black pipe in and one out going to throttle area and electrical plug on top and makes a ticking noise now and then) but I just keep clearing it and it comes back on again in a couple of days. In fact I've got bored of clearing it now and it's on all the time :-)
