VRS Rear passenger window stuck shut!
Went to open my rear passenger window last night, wouldnt open so i thought it might need a bit of de icer, it was freezing.
Tried again today but still no luck.
I can hear the motor whirring and the window moves about half an inch, but other than that wont budge :(
Anyone shed any light as to what the problem could be?
Regulator I think. Just to confirm, you get the same problem with both the individual door switch and the one on the driver's door?
Yep same problem with both switches.
Thanks ill look into that.
Almost sure it's either the window regulator or the motor gearbox then. Unfortunately physical investigation is required to decide which.
Right an update.
Window fell into door on the way home this morning!.
Tried to put it back up and i can hear the window motor whirring and stopping when it thinks its reached the top however the window doesnt come up at all :mad:.
Any ideas please?
Regulator. If you're lucky it's just detached from the glass; if you're not then the carrier's broken.
ok cheers mate!
