Add coming home function
Dear All,
Good Day
My car is Octavia 2009 1.6 mpi; I want to add coming home function to it if possible
Thanks for your help
REGARDS
any help
Most people on here work, they will get back to you this evening!
If they have details for a 2009 car, that is!!
try a search mate. There is a HUGE thread about this and the auto tunnel light function being retro fitted....
Hi moshneb
Try this with VCDS (Vag-Com)
09 CENTRAL ELECTRICS 07 CODING LONG CODE HELPER
ASSISTANCE DRIVING LIGHT _ LEAVING HOME ACTIVE BYTE 0 BIT 5 (TICKED)
COMING HOME ACTIVE BYTE 0 BIT 7 (TICKED)
COMING HOME MODE VIA _ BYTE 2 BIT 4 (0 = PERSONALISATION / 1 = LIGHTSENSOR)
09 CENTRAL ELECRICS 10 ADAPTATION
CHANNEL 01 RANGE 10 - 60 SECONDS (RESOLUTION 10 SECONDS)
CHANNEL 02 RANGE 10 - 60 SECONDS (RESOLUTION 10 SECONDS)
Or if you have Maxidot you can enable it with that.
Craig.......
Hi moshneb
Craig.......
i already have the maxidot but without this function
You will need to enable it with VCDS (Vag-Com) then. Once enabled it may show up on your Maxidot. :thumbup:
Craig.......
Craig.......
How to be added with vcds?
you need a vag com kit of lead and the software or look on the vag com section for people near you who will do it for you.
Thanks all i did it
Congratulations Well Done :thumbup:
Craig.......
