Dash playing up???
Has anyone else had the 2 little lcd screens playing up on there dash??
Mine have been not coming on sometimes just staying blank. the only way they come back on is to switch off ignition and turn it back on again, they have done it a few times now so back to the dealer me thinks??
Assuming the rest of the dash is working (LED warning lights, rev counter and speedo) it does sound like a faulty LCD controller. Easy job, as the dash panel is only held in by two screws, with only one trim piece to remove above steering wheel. Not sure of unit price, but labour should be no more than half an hour. New unit needs to be coded and the mileage set.
Looks like you've got a limited edition so must be in warranty still? Get the dealer to sort it as this does sound like a faulty part somewhere rather then a bug,... not heard of it before.
Rob.
yes got an se so still under warangy just wanted to see if anyone else had the same fault?
Very rare fault, but as said, let the dealer worry about it. :D
