Fault Code 17964 and no boost
: but the Thrust Sensor in the intercooler. Part was £37.95 + vat and an hours labour. Car drives well now :thumbup:
Part number is S038906051C
never heard of one of those , is it the same as th MAP sensor which is fitted in the intercooler ?
edit , just checked Vagcat , and it is one and the same
Good info guys :thumbup:
So should I take that if my MAP (or thrust) sensor was at fault, I might expect some of the same error codes that Irf has showing?
Cheers,
Steve
Yes it does, if you want it :D
Can't rule out that it wasn't playing some part in the issue, but on the other hand could still be 100%.
Any more ideas for possible resolution, o great one? :thumbup:
Steve
If you dont mind mate, kinda need it now :)
Car's in at Awesome today...
Failed turbo VNT mechanism is the cause. Oh joy :rolleyes::mad:
Either turbo re-build or new unit time then :D
Steve
Oh dear.
Nothing to do with that hilarious peak on the map then Steve? :confused:
Keep us posted mate.
Unlucky steve
Those few graph anomalies could well be related to this, yes. TD are going to have the unit back in to inspect, and advise further.
Just need to sort out when it can come off, and whether I'll re-fit the KKK in the meantime etc.
Steve
Steve
Hi Steve
Sorry to be right (will kick Mark later) what are you going to do?
Sarah
Get it built to stage 2 mate:thumbup:
If it is a warranty job ask TD for the stage 2 instead, even if you do have to pay a little bit more.
Just get a better map than the previous one I had:(
Hi Steve
Sarah
Hi Sarah - turbo will be taken off and returned to TD. Hope to then get it sorted under warranty with them.
Steve
how much are turbos for a vRS ?
Depends which one you get, and where you get it from :)
Uprated hybrid units from TD are around £1000. If you look in the right places, a new standard Garrett unit can be had for around £600.
Steve
Is yours a stage 2 Steve??
If its vnt mech failure it shouldn't be a problem getting it sorted with TD mate. :)
Oooh , nice one , glad it is getting done under warranty ;)
Just thought it was a megga expensive repair at this time of year too , it would not be good
Sarah
They'll need to take it in for assessment, but yes I would very much like it to be under warranty :)
It's a VB Garrett (PD150 turbo), uprated to stage 1. Didn't want mega power from it, and didn't want the extra lag from the larger compressor wheel....
Steve
