Wipers but no washers
My daughters wipers packed up - sorted with a quick fuse change BUT I've now got no washers. The motor is not making any noise so is this likely to be a simple dead motor or is there a separate fuse for this?
If it's the motor where is it?
Many thanks.
What is the temperature where you are?
have u checked all the fuses it could be? it not it will be the washer pump which will be in the side of the washer battle me thinks.
According to Haynes fuses 32(10A), 41(20A) and 15(10A) (Passenger compartment fusebox) all go to this \area--probably easiest/quickest to whip them out and check.
Hope thats some use
my wipers and washers packed up last night on my fab (happy new year) :)lets hope its is a fuse! It was cold -1 last night the back wiper worked but not the washer and about 3 days ago the light washer work for the 1st time .
Thanks guys - it was fuse number 32.:thumbup:
Nice to know that sometimes Haynes gets it right(though would'nt like to wade through the circuitry as depicted on the diag and that's as an electronics eng )
Mind you - several hours later - no response as to whether info was useful seemed like a smack in the face :confused:with a wet kipper
(If someone gets a book out to help me -least I would was say "thanks mate ")
Edited by VWD
