Washer leaking?
Hi guys,
My Bros Fabia seems to be leaking washer fluid. It is leaking from under the front of the car, there is no water coming through the back squirter either. Could there be a blockage anywhere?
It'll be one of the pipes that has popped off under the bonnet or by the washer tank - common problem if the rear wash is used when frozen up but often splits inside the rear hatch. Easy fix if you can get at it and trace the pipes to the break (The washer bottle is in front of the nearside wheelarch behind the bumper so the pipes run from here through the engine compartment under the battery and then through the car)
