some new fault codes
cars been fine up until this week when its got cold and im getting several fault codes.
1. e22 wiper switch, is this because i forget to move the intemdediate bit (on top of stalk) back to the left after using it?
2. 01135 - Interior Monitoring Sensors
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 3
Reset counter: 137
Time Indication: 0
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 134
Mileage: 11913 km
Time Indication: 0
Date: 2000.00.00
Time: 18:58:30
is this because its cold or does it mean new sensors?
3. 005782 - Powertrain Data Bus: Implausible Message from Steering Column Controller
P1696 - 008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 69.0°C
Readiness: 0000 0000
I also had a cruise control error two on the same line as the wipers but ive solved that one by using the workshop code (following a search on here.).
is this all down to the extreme temps we had or more?
and now fault number 5 with nothing touched:
VCDS Version: Release 805.1
Address 09: Cent. Elect.
Control Module Part Number: 3C0 937 049 AE
Component and/or Version: Bordnetz-SG H52 2002
Software Coding: A18E0F111004140000110D000000000000097F065C0000
Work Shop Code: WSC 73430
Additional Info: 1Z2955119C Wischer 150307 022 0601
1 Fault Found:
02390 - Control / Regulation for Ambience Lighting (E400)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01111001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 115
Mileage: 31792 km
Time Indication: 0
Date: 2005.09.13
Time: 31:63:63
Freeze Frame:
ON
Voltage: 12.00 V
ON
ON
OFF
OFF
OFF
cleared fault and gone, but it keeps appearing.
Wiring, power supply, battery... Can be all sorts of things...
no probs!!
