Rear Wiper Speed, Indicator Flashes
Hello all,
Just want to check and see if the following are changeable via VAG_COM:
1) Rear Wiper Speed? I find it's far too quick for most driving conditions, tends to be wiping an almost dry window most of the time.
2) Indicator Flashes (when tapped)? I find 3 flashes isn't long enough, I've heard you can change it to 5, which would be much better, but can you change it to anything else? I'd probably go for 5 or 6 if I could set it to anything.
Regards,
Richard.
