octavia MK11 - Merged
HI ALL new to this
have a 2005 octavia 1.9 tdi pd new model
changed timing belt & warter pump all good Q
drove the car for a few days and seemed to lose power
lifted the bonnet when i reved the engine the pipe feeding the vacum
seemed to deflate nearlt cut out the engine
put on the computer got these code
16603 po 299 turbo in one-
super charger wire
boost sensor (a operating
) circuit mode
underrboost
CAN YOU HELP
[email protected]:mad:
This code usually means a bad hose or a bad N75 solenoid valve. Vacuum hoses should not collapse, so I would say the hose is bad or is not a vacuum hose.
i rang a skoda dealer today for add he siad take off the pipe on the side of the turbo and cq the blades inside if there is alot of play morn than 1mm the turbo needs replacing has anyone had this prob did you replace the turbo how (much is a turbo)
octavia mk11 1.9 tdi pd
[email protected]
ireland
It might be something more simple. You need to have a diagnostic check done.
VNT vanes sticking is very common, could be much more simple such as N75..
Edit - --------------------------------------------------------------------------------
I just found your other thread so I'll merge them both for you,
If you have a vacuum hose collapsing, then you need to get the hose replaced. You will get an underboost situation if the hose collapses and prevents VNT actuation.
ARE the vnt vanes easy to repair can they be cleaned or is it a new turbo
we took off the pipe leading to the turbo and the vents are jamed solid
my mec siad we need to replace the turbo. skoad dealer price (1700 supply & fit euro plus vat 21.5%)
or we got a price of (700 euro inc vat) from a turbo dealer
The vanes can be cleaned if they are stuck but get that bad hose replaced first. To test the vanes, your mechanic should put a hand vacuum pump on the actuator hose and create a vacuum. This is the only way to see if the actuator is working correctly.
If you or your mechanic need to know what you are dealing with then take a look at
http://www.technologie-entwicklung.de/Gasturbines/VNT15-Turbo/body_vnt15-turbo.html
Edited by rwbaldwin
