rns-510 help
hi all i am thinking of upgrading my mfd2 non dvd unit in my octavia elegance to the new rns-510(columbus) . what i want to know is will the standard iso cables clip straight in and let me use the system straight away and will it display sat nav signals on my maxi dot display, also will the sat nav antenna i have factory installed clip in to rns-510 as the seller on ebay is giving a new antenna with unit. also is this seller safe anyone? Navbmtech921 from lithuania. and what tools do i need to remove faceplate plastic, also will the standard 6 disc changer clip in and work with rns-510. thanks
Edited by yas-uk
I can't answer all of your questions - but I'll start :)
Yes - the 6 CD autochanger in the boot willl happily work with the RNS-510
With regards the plastic trim surrounding the unit, I simply used my fingers around the bottom part where it "curls" under and pulled.
Once it was unclipped from the bottom the rest of it came out pretty easily.
The EBay seller you mention has been used by at least two other people here and they have been happy with the service/unit.
I'm sure somebody will pop along shortly to give you the answers to your more technical questions.
If you do replace the MFD2 will you be interested in selling the old unit? (hint hint)
