Ths performance decat?
Anyone seen these on ebay?
A decat is a decat. I like my exhausts to be custom made, so I go to my local place. Decat's are relatively easy to make up. Personally, I wouldn't take my chances on a ebay one (manufacturing might not be up to particulary good spec).
Where did you have your exhaust done?
Powells Performance in Pool. Nice chaps, but they were unwilling to make a batch up. They use eurosport stuff. I had the tip which is the same as the standard vrs one, but slightly larger.
google for "powerflow" - they will have a nationwide network of exhaust dealers / approved fitters/ Their decat pipes are about the same as anyone else's, although you can have cheaper by checking around any of your local exhaust places. Anyone should be able to chop out the cat and weld in a bit of pipe the same size. :thumbup:
Don't go to the powerflow guys in pool though. Can't remember the name of the company, but they are a serious rip off. On my golf, they wanted £140 to put a mild steel decat on.
Milltek do a decat for the Fabia vRS ;)
Decent price and good quality
Sarah
Funny you should say that, i use to work for them many years ago before they started doing exhausts, they done my s1 rs turbo, but not in the required bore size, and my 2wd cosworth which they bodged up on the turbo, definitely wont be going there!
Sarah
If it would fit my standard system i would order one from you good people.
