Koni fsd's and -30 eibachs...do bumpstops need trimming?
is it imperative or not.....ta
Fronts, I would.
Rears, Should be fine.
ok ross thx
Where would you trim the stops on the front ross and by how much?
I only trimmed the rear ones by about 10mm when i just put the Eibachs on.
Didn't bother with the front ones, as i wasn't sure how much to take off. And not really experienced any crashy ride.
And the roads around here are full of potholes.
I usually just lop the chamfered bit off.
reading thru threads they say cut 30mm off the bottom of the front ones and 30mm off the middle ov the rears then araldite back together..i just wanted to know if it were imperative...
Sorry, just realised this is for the Fabia I
u got a cortina?
ran oem bumpstops, was fine :)
u got a cortina?
Yes of course!
I only use the Veyron at Weekends though! ;):thumbup:
