clutch?
Hi does any one no if a clutch from a golf pd 150 or seat pd 160 would fit a 04 fabia vrs
Don't think so. I think the clutch plate is larger in the pd150
the clutch discs are the same diameter ,240mm, but the flywheel , clutch cover and therefore clutch disc are different iirc, and probably the clutch slave cylinder too
The PD130 and PD150 clutch kits are the same part number. I thought about that too... Flywheel and slave cyl may be different though... :thumbdwn:
new it was something along those lines
