2002 Octy vRS - rubbing noise from rear wheel
Hi,
As it says I have a 2002 Octy vRS and I've noticed a rubbing/squeeking noise from the rear passenger side wheel. It is noticeable at low speeds and gets louder when taking a sharp left hand turn. I can't hear it at higher speeds and I'm sure it's not there constantly either. Any ideas what may be causing this?
Regards.
Sounds like a wheel bearing. I had an off side one going and the noise was worse when it was under less load when turning right.
Ian
Thanks for that. If that is the case is it a big job to get sorted; I assume the bearing gets replaced?
They replace the bearing and hub assembly as it's all 1 unit. Part number 1J0598477
Ian
