Felicia power steering problem
Hi.
My power steering is rather heavy. :( I haved checked the fluid level and pipes and everything looks OK. Is there an easy way to test the power steering as I suspect the pump (or something else) is worn.
Thanks in anticipation of your help.:)
Martin Radford.
Check your front tyre pressures, and wear, because the lower the pressure and tread get, the heavier the steering gets.
As to the pump, does it sound noisy when you're going straight, or turning but not on full lock?
