Coolant Leak Fabia 1.4 MPI
Hey guys,
Had a little tinker with the Fabia earlier.. took the throttle body apart to see what was going on in there and found out the dealer had actually cleaned it up for me :eek:!!
Then I noticed the coolant bottle on reassembly and it was below minimum (again!)
I had this problem about a month ago, I took it in under the 3 month warranty and they said it was a leak from some valve/sensor on the radiator cap?? :confused: But now its leaking again!
Any obvious places for leaks or should I take it back to the dealers to sort out.. I have about 2 and a bit weeks left on this 3 month warranty so it may be worth getting them to check it out anyway before it runs out?
Thanks,
Will
Fan switch is a normal one. On the n/s of the radiator just above the bottom hose.
