Engine management light bulb
Looks like the previous owner removed mine:thumbdwn:
Went to RStuning today and vagcom gave some codes for a faulty crank position sensor, when starting the car Paul noticed the bulb didnt light
Anybody know where to get them and if they are easy to fit?
When mine went it didn't light up either, I did get the EPC light on though
when we started the car it doesnt light it with the rest of the bulbs key position 2, should it do?
Yes it should light up then. I thought you meant when it was running with the sensor fault.
Sorry my bad wording!
Sounds like a good way too turn the light off:rofl::rofl::rofl:
well its always off car never has a fault!
Most likely an LED though, not a bulb?
In which case it will be soldered in and not easy to remove.
Mine wasn't working when i got my Octy, when i went to change the bulb the LED fell out looks as if someone has had a go at it, not sure if there repairable, probably expensive fix or replacement pod. I'll live without it just get my mate to check for codes every now and again.
