Broken pipe and temp sensor
Hi guys, took the covers off to change my black sensor to the green, all sorted and fine and dandy, but.....
As the picture shows, have this broken pipe, what is it, what does it do, and is it serious?
Easy to change? blah de blah de blah??
Trust me, I know nothing......
28136.attach
Quite a common problem. It's a breather pipe. About £30 iirc and there is another L shaped one near the dipstick that tends to go at the same time. Someone will be able to help with part numbers.
Ta Matey
How soon does it need to be done?
Have a longish run coming up this weekend and dont wanna do any damage....
Ta Matey
Tape it up for the mean time and it should do as a temporary fix
Ta again
I couldn't find anything under search, but then I didn't know what I was searching for, hence the pic!
Muchos Gracias
Steve
i have just had to change mine as it started to cause me problems my car started revving high on tick over and it cause it to run with a miss fire so i replaced the lot its a bit of a fiddley job to do tho :thumbup:
Just to let you know, got the pipe changed this morning, they charged me 28.54 for the hose and a tenner to change the pipe. I was going to do it myself, but, i thought, hey for a tenner, carry on!!
That was at my local garage
Steve
Its a pretty safe bet that if that pipe has split like that then the lower pipe will not be far behind! Aslo need to check the pipes under the manifold as the long one that goes down to the Crankcase Breather splits. they all rot from the inside due to the horrible gases that they contain annd cause running lean and idle problems. If you can get access to VAG COM then log block 032 and post the results
