cable duct part no.
Does anyone know what the part number is for the square black duct that sits behind the airbox and curves up into the bulkhead? I assume it's there to protect cables from the ECU to the engine bay?
1J0 971 615 BS (Wiring Conduit Lower Part), superseeded in 2007 by:
1J0 917 615 CK
1J0 917 839 B (Cable Channel Upper Part) This clips onto the lower conduit.
(NB: The ETKA picture is not very clear so please check existing parts for visible part numbers if you can)
1J0 917 615 CK
Sorry mate the number should be :-
1J0 971 839 B (Cable Channel Upper Part) This clips onto the lower conduit
Peter
Can I get a few opinions on this... these two parts aren't mentioned in the Haynes manual and I guess not many Briskoda members ever have need to mess around with them :confused:
The cable duct mentioned above got smashed at the top and left hand side when my bonnet dented inwards, and the bottom half of the relay box (the one to the left of the cable duct) was sheared off from the plastic clip that holds it to the bulkhead. I was hoping to replace both these bits but not sure how easy it is.
Is the relay box easy to dismantle so I can just replace the bottom half of it with a new one with the clip attached?
Likewise is the cable duct easy to replace? I can see I'm going to have to remove the air box and battery but if it also means pulling cables etc out then I'd rather just patch it up with gaffer tape until I can afford to get a garage to do it!
