Price
Hi guys im after a price guide for the below all in a one
Turbo fit, front mount fit, and a clutch and flywheel fitted
cheers
shaun :)
Im in aberdeebshire if anyone fancys earning a buck or two ???
Any second now someone will say a kitten has died.
Search would have told you a price.
Your talking over £1100, and you would need a RR too.
HTH, Dave
Depends on turbo, if u have it already and if its just fitting? Then depends where you go!?
Same with everything else you said, so pretty much a useless post as you havnt given any one enough info to actually reply
I have been quoted as below
turbo 2hrs
clutch flywheel 2hrs
intercooler 2 hrs
50 ph
total 300 plus vat
RR is being done buy a seperate company
cheers for the input Guys i tried search with no luck. Just looking for a little help thats all
No problems, so you already have a turbo and the other bits and just want them fitting?
TBH, neither the turbo or intercooler is a big job.
I personally havnt done a clutch so cant say how easy, but esp. the cooler will be easy to fit, and no way should it take someone who works on cars for a living two hours to fit it.
Why not throw in a A.T.B diff whilst you have the clutch out? save abit on labour atleast ;)
