hand brake light issues ?
since i have lowered and stiffened my car if i corner quickly the hand brake light flickers on n off and the car beeps at me
do any of you have any idea why its doing this ?
do any of urs do this following lowering ?
or could it be cause my rear discs are almost warn out ?
Check the fluid level.
Check the handbrake switch on the lever.
Both are common causes for the light and buzzer.
the fluid is full and the switch seems ok
How do you know the switch is ok?
well ive taken it out n tried shakin it n that makes no dif tried pressing it in n out a few times feels ok
Did you take the centre console out to check its sat in right, or can you see with it all in place?
i lifted the rear end of it up was bloody annoyin with all them torx screws
