Login code
Hi,
Anyone know of a VAG.COM login code for my 1999 Octavia TDI 110bhp?
1U2919034G VDO V22
What are you trying to do? Sometimes the login codes are specific to your vehicle (for coding keys etc) and sometimes they are generic across models/platforms.
I want to alter my average MPG read out 'cause it's 14% to high.
Also my MPH 'cause that is 2 MPH to low
Try 13861
; VAG-COM Label File
; Skoda Octavia (1U)
; Component: J285 - Instrument Cluster (#17)
; P/N: 1U?-919-???-???
; includes measuring blocks, adaptation, coding, login and service reset
; This file is part of a redirection package,
; make sure you have all of the following files.
; 1U-17.LBL
; 1Ux-919-xxx-17.LBL
; 1U0-920-xxx-17.LBL
; created on 29/Jun/2007 by Sebastian Stange ([email protected])
; last modification: 01/Jan/2008
; requires VAG-COM 610.0 or newer
; measuring blocks
001,0,General
001,1,Vehicle Speed
001,2,Engine Speed
001,3,Oil Pressure,Switch 2,Range: Oil Pr. 2
001,4,Time
002,0,General
002,1,Odometer
002,2,Fuel Level
003,0,General
003,1,Coolant,Temperature
020,0,Immobilizer - ID Block 1
020,1,Digit 1 && 2
020,2,Digit 3 && 4
020,3,Digit 5 && 6
020,4,Digit 7 && 8
021,0,Immobilizer - ID Block 2
021,1,Digit 9 && 10
021,2,Digit 11 && 12
021,3,Digit 13 && 14
022,0,Immobilizer I
022,1,Engine Start,permitted,Specification: 1 = Yes\nRange: 0 = No / 1 = Yes
022,2,Engine (ECU),responds,Specification: 1 = Yes\nRange: 0 = No / 1 = Yes
022,3,Key Status,,Specification: 1 = Key OK\nRange: 0 = Key not OK / 1 = Key OK
050,0,General
050,1,Odometer
050,2,Engine Speed
050,3,Oil Temperature
050,4,Coolant,Temperature
; login
L00,Instrument Cluster (J285) Login
L01,13861 = Adaptation Enabling
; coding
C00,Instrument Cluster (J285) Coding
C01,??xxx: Options
C02,+02 = Seatbelt Warning active
C03,xx?xx: Country
C04,1 = Europe / 2 = USA / 3 = Canada/Mexico/Latin America
C05,4 = Great Britain (GB) / 5 = Japan / 6 = Saudi Arabia / 7 = Australia
C06,xxx?x: Cylinders
C07,4 = 4-Cylinders
C08,xxxxx?: Distance Impulse Number (K-Value)
C09,0 = Diesel Engines (excl. TDI 81kW from MY 1999+)
C10,2 = Other Engines (incl. TDI 81kW from MY 1999+)
; adaptation
A002,0,Service Reminder
A002,5,Service Reminder
A002,6,0 = Service NOT Due
A002,7,1 = Service Due
A002,8,
A002,9,To reset the service reminder save 0 as new value.
A003,0,Consumption Correction
A003,5,Consumption Correction
A003,6,Standard Value: 100 %
A003,7,Display Range: 85...115 %
A003,8,Increments: 1 %
A003,9,
A003,10,Calculation based on volume per distance (e.g. l/100km):
A003,11,New Adaptation Value = Old Adaptation Value * Calculated Consumption / Old Display Value
A003,12,Calculation based on distance per volume (e.g. MPG):
A003,13,New Adaptation Value = Old Adaptation Value * Old Display Value / Calculated Consumption
A004,0,Language
A004,5,Language
A004,6,1 = German
A004,7,2 = English
A004,8,3 = French
A004,9,4 = Italian
A004,10,5 = Spanish
A004,11,6 = Portuguese
A004,12,8 = Czech
A5,0,Service reminder - Maximum distance for oil change "OIL"
A5,5,Service reminder - Maximum distance for oil change (in 1000km)
A5,6,15 - 15.000km (Standard)
A6,0,Service reminder - Maximum distance "INSP 01"
A6,5,Service reminder - Maximum distance (in 1000km)
A6,6,30 - 30.000km (Standard)
A7,0,Service reminder - Maximum time "INSP 02"
A7,5,Service reminder - Maximum time (in 10 Days)
A7,6,37 - 370 Days (Standard)
A009,0,Mileage/Odometer
A009,5,Mileage/Odometer
A009,6,Increments: 1 = 10 km
A009,9,The distance can only be changed once until
A009,10,the current value is not over 100 km.
A009,11,
A009,12,NOTE: Perform Login first.
A10,0,Service reminder - Distance for oil change "OIL"
A10,5,Service reminder - Distance for oil change (in 1000km)
A10,6,15 - 15.000km (Standard)
A11,0,Service reminder - Distance "INSP 01"
A11,5,Service reminder - Distance (in 1000km)
A11,6,30 - 30.000km (Standard)
A12,0,Service reminder - Time "INSP 02"
A12,5,Service reminder - Time (in 10 Days)
A12,6,37 - 370 Days (Standard)
A016,0,Distance Impulse Number
A017,0,Distance Impulse Number
A021,0,Immobilizer - Key Adaptation
A021,5,Immobilizer - Key Adaptation
A030,0,Tank Characteristic (Fuel Level Sensor)
A030,5,Tank Characteristic (Fuel Level Sensor)
A030,6,This channel is used to set the fuel gauge reserve mark
A030,7,therfor fill the tank with 7 l of fuel and correct the
A030,8,needle to hit the reserve mark. This is a parallel shift
A030,9,of the tank characteristic.
A030,10,
A030,11,Standard: 128
A030,12,Range: 120...136 (-2.0...+2.0 l)
A030,13,Increments: 1 = 1 Ohm = 1/4 l
; service reset
RD,2,Service Reminder Status,1,
RD,10,Oil Change (OEL),1000,km
RD,11,Inspection 1 (IN1),1000,km
RD,12,Inspection 2 (IN2),10,Days
RJ,0,0,Service Reset (Oil Service),,
RJ,0,1,10,15
RJ,1,0,Service Reset (Inspection),,
RJ,1,1,10,15
RJ,1,1,11,30
RJ,2,0,Service Reset (Oil Service & Inspection),,
RJ,2,1,10,15
RJ,2,1,11,30
RJ,2,1,12,37
Thanks for all that :) but unfortunately I tried that one and it doesn't work. Do you know any others?
Unfortunately not, it could be worth contacting Ross Tech and explaining what you'd like to do :thumbup:
The last couple of 110 Octavia's i have done both worked on 12233.
HTH
