hello
just joined the forum at present im on my 4th skoda 2 octavia 110hp diesels and 2 superbs 110 hp and now a 140 hp going through the forums i can relate to most of the problems I see particulary those Bl**** parking sensors :mad: the only solution is replace the full kit with a spurious set cheaper in the long run - here in Ireland if it dont work the first time modify it!
by the way has anyone come across a problem with intermitting brake fade - pedal hard like the servo pump not working then returns to normal -- what the solution please
Welcome :)
welcome to briskoda
Hello :)
welcome
Hiya.
The pedal going hard is not brake fade. Brake fade is likely to be either normal pedal but no stop (pads overheated), or pedal going to floor and no stop (fluid fade). You'll probably get a better and more specialised response on the Superb forum (1 or 2 as applicable to your car) though.
