Anyone Help??
I am trying to replace the badges on my Octy VRS I purchased 2 days ago, I have done the front one, that was easy enough, but I am struggling to get the rear one off!
I have tried getting a hair dryer to melt the glue but that did not work, tried sticky stuff remover but as you can guess that did not make the slight bit of difference!
Anyone else done it before? Don't want to use a screwdriver as you can imagine because it will damage the paint work!
PS: Will post my car up when the weather is abit better and I can take a good picture lol
I think most people use a hair dryer to warm it up and then gently slide a bit of thin fishing line behind it to cut through the glue.
Hairdryer should work plus there is two locating pins on either side.
Cool, I shall have to spend abit longer on it tomorrow and see if I can shift it. Will definatly have to try using the fishing line!
Is there holes drilled in the rear boot for these badges? I wanna remove the rear one from mine!
If it's the skoda badge you mean, then yes there are holes :)
Thanks but I mean the VRS Badge! Sorry
Then theres no holes:)
