New air filter
Was having a browse on the net today and I came across this.
Waxacar Green Performance Air Filters
Seems to be a mixture of the BMC CDA filter and the green panel filter. Looks totally customisable depending on size required etc. The only thing that would need thought is attaching the MAF on to it, although I suspect this could be done using the correct size of silicon hosing.
Anybody else heard of these?
You would have to get the biggest one possably, which isnt a problem, as they also do "Rubber Anti-vibration reducers",.
So you could have a really big filter and reduce it down to the MAF size.
Job done.
Dave
That's what I was thinking. I'll get it ordered and see what I can do. Should work nicely with EGR delete and CCV mod :)
Does anybody know the MAF size off the top of their head?
The top of my head doesn't have a MAF sorry :rofl:
Ah must just be mine that does :rolleyes:
What about the MAF from your airbox instead then?:rofl:
I want to say it's 83mm?
Bump
yip 83 mm my samco says :)
Perfect, thanks!
Just make sure you dont fit the maf round the wrong way like i did.... :(
Get you home mode and a fault registered. Swapped it back and it all cleared, phew:P
Ooo forgot to say induction kit was soooo monumentally noisey i went back to original box and pipercross panel filter.
Which one were you running Moffball?
And what sort of noise did it make?
I am ashamed to say i made an impulse buy and bought a stainless steel jobby from halfrauds.
As for the sound it was a surpisingly low bassy note as if my exhaust had fallen off, combined with a few wheezes and splutters when lfiting off. It wasn't a particularly bad tone just a bit much when you are doing 600 miles a week on average.
Pick up was a bit slower than my pipercross panel job and top end was a bit restricted. I guess it's a trade off nicer sound or more power/driveability.
Edited by Moffball
I'm a numpty who can't spell
