PAS Pump
Hi guys,
Just wondering if the PAS pump is difficult to remove? Im taking one out of a 2000 1.9SDI Fabia, as it has a leak between the pump and the resevoir. Going to attempt a reseal!
Any advice is appriciated.
Thanks guys,
2012.
remove the nearside arch wing liner,and the pump is on full view.The liner has 4 torx headed screws inside the wheel arch towards the front.Then there are about 3 torx headed screws which are along the front of the lower engine cover (big black cover underneath the engine. You dont need any ramps or jacking up. The front of the wing has an area about 9 inches which is a push fit into the front panel on the car(where the wing meets the front panel. About 3 months ago I replaced my PAS pump which had stopped working. If you search the forums there are pictures and details of how to do it
Hey thanks for the response. Managed to remove the pump, the resevoir had come of its seal with the lower pump. Managed to reseal the two and refill, so its a waiting game now to see if it holds !
