Just a broken wire!
Well - after a thorough check of my MAP sensor wiring today - found a busted wire. I did wonder why vagcom was persisently coming up with the open/short fault code! :thumbdwn:
Anyway - As a temp job I got all the solder off, cut about an inch off each part of the shroud (not oem wiring, some "added in" ;)) and did a twist job to join it, and sealed up with some duck tape I had in the car. Fault codes cleared, job's a good'un!
Got BOOOOOOOST back! :D
A temp job? surely it should be good for years.
It felt solid enough for me not to worry about it. Although I think I will replace the duck tape long term.
