flaming glovebox handle
handle just come off glovebox.:mad: second time this
as happened first time done under warrantee.
now down to me .
does anyone have an idea on cost?
john
as anyone ever fitted one of
these with the airbag shut off switch
at the top of glovebox.
john
'flaming glovebox handle' surely that should be a factory recall.:D
sourced a secondhand glovebox off fleabay
gonna have a go at fitting ,doe's anyone know
what the
safety precautions are on working on airbag system.
thanks john
Hi John,
Changing the glovebox is pretty straight forward. You will be fine with the airbag system so long as the ignition is turned off.....but it wouldnt hurt to disconnect the battery. If you dont disconnect the battery; once you have un plugged the airbag switch do not turn the ignition on until you have finished the swap over otherwise you will get an airbag fault light come on.
Hope this helps
Terry
Edited by Hols595
thanks alot mate.
anyone trying similar.
found out the safety precaution is
disconnecting battery then leaving
for one minute before starting work.;)
after connecting battery back you have to
reset clock ,radio and sometimes the
electric windows because they forget where they are.
john
