Cleaning The Narrow Bit Between The Front Seats And The Doors
The narrow bit on the floor between the seats and the door pockets are a right pain to get clean, anyone got any tips to clean this part of the car up.
If you have the time,take out the front seats which is what i do when i clean my seats and you can give it a good hoover and clean at the same time.I started doing it when i saw all the dirt that builds up aswell.I do this twice a year.I hope this helps.
Do you need special tools to do this.
I just got a 8mm allen key,cut about 2" off it and put it into a 8mm socket along with the extension bit for the ratchet.A tip for you, put a bit of blue tack in the socket bit to hold the bit of allen key,stops it from falling out.
easiest way i found was to use a very thin paint brush from b&q - about 99p and works a treat!
:cool: The brush would be a lot less hassle :D
just take the seats out, gives you a lot more space to do a better cleaning job on both the inside of the car and on the seats
thanks i always wanted to know a way to do it, but i might stick with the brush as in my experiences when taking things out is easier than putting it back in.
Me too :D
