Remapped TFSi and performance with dodgy fuel
Hi,
I have a moderately remapped Octy II TFSi VRS which seems to have dropped in power and MPG - nothing drastic, but notable. I have also had one or two 'clackety' starts when starting the engine from both cold and warm. The only thing that I can think of that would correlate with when this started was filling up with BP Ultimate 97 RON fuel before the weekend. Previously I used 99 RON from Tescos.
I know that a remapped engine should use premium unleaded but I would have thought that BP Ultimate would cover this and would be surprised if there was not good control of quality in the UK. I was therefore wondering if anyone else with a remapped TFSi had experienced problems with this or a dodgy batch of premuim unleaded in general and did it cause similar symtoms?
I don't think fuel is your problem but more likely to be a diverter valvle failure. Quite a common issue as thse tend to split especially with remapped cars causing a lack of boost but there is a newer version which corrects this issue or there is an aftermarket one from Forge.
Definately worth getting checked out :thumbup:
More details on this and loads of other stuff can be found within this sticky thread
Thanks Makefish
I considered this possibility and certainly haven't ruled it out. However, I am not seeing the big drop in boost that a DV failure would suggest. If anytrhing, the symptoms are more like the Positive Crankcase Ventilation failure described in the link you gave (but without oil on the filler cap). I also considered the MAF sensor.
I guess it could be a bunch of things. I just wanted to rule out the dodgy petrol idea since it coincided (sort of) with the issue. I guess the easiest thing there is run the tank low and fill up at Tesco again!
