Ecu
Hi,
Just wondered if anyone could assist me in were to locate and remove the ECU (for postal remap purposes).
Cheers.
it is under the Black things at the bottom of the windscreen mate,
remove the wiper arms and the seal then remoce the plastic buits .
carefull when removing the 2 plugs from the ecu,
What Remap you goin for if you dont mind me askin?
billy
ECU evolution.
Ive heard good things from guys on here.
I'll have a look in a moment to see how to remove it.
No need to remove wiper arms the scuttle (i think it's called that) just snaps upwards and move to a side. There is a little tab on the side of the Ecu runners which needs to be bent to the side a little.
I just propped them up with some wood and got it out.
yea you can do it that way . But i found that the plastic kbits on mine dont go back properly and they are up a mm or so. Might jus be the way it was fiddled with.
billy
ECU evolution.
did you get the ecu back mate?
what do you think as i am considering ecu evolutions when i decide to get mine remapped
cheers
