Bury CC9060 Car Kit
Hi, I am getting a Bury CC9060 fitted to my Octy tomorrow, I have the "sound system" upgrade, is anyone aware of any issues this may cause the fitter when wiring up the call mute feature ??
if the bury uses its own amplifiier to drive the speakers then the unit will not function with your car as it does not have the required connections to the speakers. Your only hope is to use the phone input on the headunit, and use that along with the mute function to get the sound out of the speakers. Doing it this way will only give mono audio, so if the bury supports A2DP then that part of the bury will be useless to you.
Hi, I got the Bury installed today, looking great but not working properly. When the power is interupted from the display unit either by switching the ignition off or taking it from its cradle it will not switch back on properly, to get it back on I have to completely disconnect and then reconnect (reboot) the control box. If I do not do this the unit will connect to my phone but the display stays blank, can anyone shed any light on this ??? ( when I say blank, there is power going to it but it is just lit up white)
