PD100 tuning questions
Hello
I've searched around and found most of the information I need on this site.
I actually have a PD100 polo.
I've been looking at tuning the PD100 on a budget, I have decided to do the following after searching on here
Change intake for PD160 item
Cat replacement pipe (home made)
And upgrade the turbo and injectors to a secondhand set off a fabia VRS
Then a custom remap.
The only question I have, after researching the turbo's I have found both the PD100 and the VRS use a BV39 turbo.
Are there different versions of this turbo?
Why will the 100pd only go to around 145bhp on it's standard turbo, but more with the VRS?
Thanks for any info
Edited by scruffydubber
Bump this up. 40 views and no comments
Does anybody know if there are different versions of the BV39 turbo. Or could confirm the turbo's that's fitted to the 100pd and the 130pd VRS
the PD130 has a bigger turbo and bigger injectors I beleive, which is why you get more power.....
145bhp sounds about right for a remapped PD100 with standard mechanicals
Vrs uses a different BV39. If you can get a 1749VB garret.
That's great info thanks
Do you know if the 1749VB is a direct fit?
Would a VRS Forge FMIC fit a polo PD 100? Just a thought & scruffydubber You have PM!
Edited by Motoract
BUMP on the fitment of the turbo!
i think it does, but a search will let you know for sure. I know someone who has mapped his pd100 to 160bhp with no issues as yet
matt
I've searched... but found nothing...
