02390 - Control / Regulation for Ambience Lighting (E400)
009 - Open or Short to Ground
I got this fault code. I can clear it but after new list of default codes it appears again? Do you have any idea? Where is that "ambience lightning"?
ambient lighting is a feature on the top of the range models that give lighting in (IIRC) footwell. it sounds like the option has been enabled via vagcom and as your car doesnt have it or the wires in place its causing it a short to ground.
I have that option disabled...so it shouldn't make any problems
