More air con questions
Hi Guys
This may be a dumb question , but is it true that one of the fans on the radiator is for the A.C unit? and if so should it activate when the AC is turned on ? and if it doesn/t does that mean that the Ac is knackered? as mine only works intermitently and how can i test the fan?
Both of the fans should come on when running the air con but they do go off after a few moments when at speed.
When I switch my air con on, they come on about 2 mins after switch on.
If they don't switch on it can be a sensor in the engine bay that can break, so look at something like this before any bigger probes.
The gas can be gone too.
Edited by DGW
Redundant quote deleted.
