Towing vRS
Hi folks,
Last weekend had a dead battery and wanted to tow my vRS just a bit to get it started, but unfortunately could not remove the cover in the front grill where the loop is supposed to be screwed in. The owner's manual also didn't help, 'cause that operation is explained only about the regular octy :(
Can anybody give a hint how it should be done properly with no damages :thumbup: and which side of the grill - right or left? Hope this thing on UK octys is on the same side :)
Thanx a lot.
cant remember which side of grille but you can remove the inserts by gently prising it out with a flat knife from the top crease
