yes or no??????
is my clutch hidrolic(sorry if spelling is wrong lol)or cabble on my fabia vrs ?????
Pretty sure it's a hydraulic clutch operation mate
ok thanks bud:):).....do it change from cabble to fluid at any point ????
no, always been HYDRAULIC
Yes totally hydraulic, it uses the brake fluid with a slave cylinder inside the gearbox, as part of the thrust release bearing.
so what are the 2 cabble lines that go on top of my gear box ????
Gear change cables mate.
ohhhh i seee......has it ever been known 4 the fluid ever to leak on to the cluch or dmf??????
If it does leak you'll be losing fluid. Do you have a clutch problem?
yeah its slippin (read slippy slip)but the reason i ask is that i have warrenty on the car and they will only replace it if its contaminated instead of worn.....so with-in reason im hoping that to be the cace or i will have a bigg big bill to pay :(:(
Clutch fluid contamination would be minimal, and tends to cause snatching rather than slip. So more than likely it's the clutch plate that has given up.
bugger ...... ok thanks bud:)
