i though i had her set up
i was sure i had the best outta her fabia vrs, running on coilies and polybushes, but fitted upper and lower strut braces and jabba rarb, lethal job the car is now complete
thanks to all who supplied this
whats the current price on front struts??
I didn't find the SEAT Sport upper front brace or RAAAARB made a major difference to my Ibiza. The diff on the other hand...
made a big difference, i think 50pounds for the front lower, btu it is quite low when the car is lowered
Any info on the lower strut brace? I fancy trying one out as it's something I've never done. :) I probably won't be able to tell any difference as my peloquin helps so much putting the power down right where it is needed.
i think it has just stiffened the car up under heavy cornering
the whole car feels alot tighter but i fitted the rarb and the front lower together so could be just the rear
If you don't notice a difference with the RARB then you ain't driving it right! :P
part of it might be that I hadn't had the Ibiza too long before fitting the RAAAARB and my point of reference was still the previous car, which still turns in and generally drives nicer than the Ibiza does :o
