Reset Octavia Mkii back to variable service via vcds
hi all
my mate has a mkii octy (05 reg) 1.9tdi 4x4 and has just had a service at an independent where theyve used long life oil but told him its not possible to put him back on variable and have put him to fixed! He wants to go back to variable as hes only just had it done and with the garage not being up to it hes asked me if vcds can be used,
Ive had a search around here but only really found threads for mk1 octys.
Is it possible after being put to fixed and whats the best method in vcds. I found this on tyresmoke.net but it was for any audi so not sure if it is correct
VAG Com procedure.
[select]
[17 - Instruments]
[Adaptation - 10]
Enter channel 02
[Read]
The "Stored Value" is the current value for that channel.
Enter the "New" value of 0 (zero)
[Test]
[save]
thanks in advance :)
Use the SRI Reset function and when select Variable.. job done :thumbup:
thanks shark. is that off the main menu in vcds? (ill go an check on mine later to try and find it)
wish there was a virtual vcds i could play on in the house!
Top right of the main screen, as soon as you load up VCDS :thumbup:
